Failed to publish globe service on ArcGIS Server. Error 001369
I'm trying to publish a globe service on our ArcGIS Server and in ArcGlobe I get this error message
"Failed to publish service."
---> Went to Results: [h=1]001369 :
Failed to create the service.[/h] [h=2]Description[/h]The creation of the service failed. This is a generic error. Many different conditions could cause this failure. Check the server logs for the specific issue.
[h=2]Solution[/h]Check the server logs for the specific issue.
--> Went to ArcGIS Server Logs:
SEVERE 22.08.2013, 10:15:20 Failed to construct instance of service 'glob_4.GlobeServer'. Server SEVERE 22.08.2013, 10:15:20 Failed to initialize server object 'glob_4': 0x80030003: null Server SEVERE 22.08.2013, 10:15:20 (null) glob_4.GlobeServer
Unfortunately I really don't know how to solve that. The service is published (I can see it on the server) but apparently it cannot start. I also tried saving a service definition file and then publishing it on the server-> same problem.
So thanks for any advice.
PS: We use ArcGIS Server 10.1 on Linux
