Failed to create memory layers in QGIS application on Linux
I have written a python class which reads properties of map layers from an XML file and creates appropriate memory layers. I have developed and tested this code with QGIS 2.8.2 on a Windows 7 machine (importing the class at the python console and calling the class methods). As the module should be used in a Linux environment I did the same successfully with QGIS 2.8.2 on CentOs 7 - all map layers were successfully created and symbolized.
Then I refactored the code to fit in the framework of a QGIS standalone application. There are major problems with threads and such stuff, but the app starts and comes up with all layers created, and working methods.
Now comes the strange part. In the standalone CentOs version the creation of memory layers doesn't work - layers are not valid. Even a simplified test without field definitions, no crs doesn't work.
layer = QgsVectorLayer(type + '?crs=EPSG:' + str(epsg) + fields, layer_name, 'memory')Hundreds of lines of code before and after this line are the same in all versions. Has anybody an idea how to handle this problem? Maybe a bug?
