Extruding a 3D stack of polygons on top of a map, e.g. with KML
I have data for the composition of rock layers in several polygons on earth. I would like to plot a stacked chart of the rock layers, colored based on layer metadata. Here's a mockup, where rock layers are extruded downward from surface polygons:
So far, I've been experimenting with making this visualization using KML. From the samples, I've found how to extrude above a single polygon, but I haven't been able to make a stack.
How do I modify this KML to produce a stacked set of extruded polygons? The two extrusions are unfortunately intersecting currently.
KmlFile 1.5 7dff0000 Absolute Extruded 1 #unknown 1 1 absolute -112.3396586818843,36.14637618647505,1784 -112.3380597654315,36.14531751871353,1784 -112.3368254237788,36.14659596244607,1784 -112.3384555043203,36.14762621763982,1784 -112.3396586818843,36.14637618647505,1784 Absolute Extruded 1 #transBluePoly 1 1 absolute 2000 -112.3396586818843,36.14637618647505,2000 -112.3380597654315,36.14531751871353,2000 -112.3368254237788,36.14659596244607,2000 -112.3384555043203,36.14762621763982,2000 -112.3396586818843,36.14637618647505,2000 Here's a screenshot (using the KML interactive sampler):
I'm dissatisfied with the polygons intersecting color-wise.
(There is also the limitation of extruding up from the surface -- my workaround is to set an altitude above the surface of the earth at which the "extrusions" will start, and then extrude downward from that altitude, so the rock layers will float above the surface.)
If there are go-to ways to do this in ArcGIS or some other package I haven't considered, please disregard my KML approach and suggest the easier way!
