I have a shapefile with polygons representing unique populations. I want to determine contiguous polygons in my shapefile, and then extract the border separating contiguous polygons as a separate polyline file. Importantly, I require the created polyline file to indicate the two polygons it separates.
I am aware of Polygon Neighbor to produce a table of all contiguous pairs, but this doesn't help me extract borders as polylines.
Consider group A in the following example map:
Group A has 8 contiguous pairs: AB, AC, AD, AE, AF, AG, AH, AI. I would like the output file to separate the aggregate border for group A into 8 separate lines, each line referencing only the shared border between each contiguous pair; e.g., the border of AH in red would be a single line in the output data. As noted before it is important that the output file also identifies the two groups each line separates.
To clarify, I require a general solution for all possible contiguous pairs in my dataset. I do not have a single group such as the example group A that I am interested in.
This question is similar to Extracting polyline of border between differing polygons using R or GRASS?, except I'm interested in a solution using ArcGIS 10.2 for Desktop. I have some knowledge of Python if an ArcPy solution is easiest.
