Extract multiple grids from HDF with subset tool using ArcPy
This should be fairly simple thing but bugging me at the moment. I have ~5k HDF files in a folder with names:
MOD11A1.A2001001.h24v05.005.2006343042921and so on.....I have following which loop through all of them to extract a subset grid from each HDF file. For unknown reason, python script breaks down every time at around file number 3557. I am able to manually extract several grids around that number from HDF files. Maybe, I am hitting RAM limit. But even with all other applications closed, it exhibits same behavior.
rasters = arcpy.ListRasters("*", "All")for inLST in rasters: f = inLST[9:16] outLST = "D:/temp/subset/" + str(f) + '_lst' arcpy.ExtractSubDataset_management(inLST, outLST, "0") Is there any alternate to arcpy.ListRasters, which I can use?
