ArcGIS 10.0
I'm very new to ArcGIS, and GIS is general. I am trying to build a script that will extract metadata from orthoimagery .tifs. Below is my test code to see if I can get the metadata from one file. It is basically the code from ESRI's docs on arcpy and the metadata toolbox.
When I run the tool from ArcCatalog, I get results. So, I'm stuck.
Thanks in advance if anyone can point me in the right direction.
import arcpy
from os import path
from arcpy import env
env.workspace = path.normpath("E:/RESOURCES/TEST_RESOURCES/Pasquotank/TIF/data")
dir = arcpy.GetInstallInfo("desktop")["InstallDir"]
translator = dir + path.normpath("Metadata/Translator/ESRI_ISO2ISO19139.xml")
arcpy.ExportMetadata_conversion(path.normpath("E:/RESOURCES/TEST_RESOURCES/Pasquotank/TIF/data/OC6i0_37_000_20793902_20100411R1.tif"), translator)
When I run this is get the following error.from os import path
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000816: The tool is not valid. Failed to execute (ExportMetadata).
I've tried just using the file name as the first parameter in the ExportMetadata_conversion(), and got the same error. ERROR 000816: The tool is not valid. Failed to execute (ExportMetadata).
