So i have several folders which each contain a gdb.
Now, I export the attribute tables of polygon feature classes using the following code (probably could use some optimization):
folder = arcpy.GetParameterAsText(0)for dirpath, dirnames, filenames in arcpy.da.Walk(folder, datatype="FeatureClass",type="Polygon"): for filename in filenames: fc = os.path.join(dirpath, filename) table = dirpath + os.sep + filename + "_Table" result = arcpy.GetCount_management(fc) if int(result.getOutput(0)) > 0: print "Creating " + table arcpy.CopyRows_management(fc, table)Output looks like:
-folder--subfolder1---*.gdb
