I have an application that exports an SVG after reading in a shapefile (thanks to iant for the exporting bit). You can view the code here: Exporting Shapefile to SVG using Java & GeoTools?
What I am wanting to add as a functionality is to be able to export the layers along with any other data to the SVG format. It would also be helpful to be able to select what layers to keep and export.
