explode features based on numerical field
I have a set of data as polygons, each with a Number field with value X. Is there then a way to copy this into X number of polys at the same location? (ideally points distributed across the poly but that's a bonus).
In QGIS I have tried Random Points, but this doesn't inherit attributes, and Join Attributes by Location is useless if the parent polys overlap.
The reason behind this is for collating data easily with the GroupStats plugin.
