I have developed an visual application using ArcObjects SDK for Java 10.2 which worked well until yesterday.
Since, I'm facing a fatal error (full trace below) while I don't feel I have changed anything.
The crash occurs when a JFrame is created containing a PageLayoutBean, then the JVM calls NativeObjRef.getJdk13WindowsHandleNative(), and then the ntvinv.dll calls Java_com_esri_arcgis_system_EngineInitializer_initLicensing.
According to the description of the file, Ntvinv.dll is
I don't see where licensing could be a problem as ArcMap starts well, and the other ArcObjects calls also work.
I just discovered that there was a similar function available in Java:
public static void initLicensing(int product, String pathToBin)Initialize the ArcObjects for ArcGIS Server with options optimal for usage in a ArcGIS ServerMaybe parameters are wrong..
For information, I run the program from Eclipse but the error also occurs running outside.
Is there any configuration used by this ntvinv.dll such as registry key or environment variable?
This problem is very blocking for me, so I would be very grateful to get any help.
Here's the error log:
## A fatal error has been detected by the Java Runtime Environment:## EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x7ce71790, pid=3848, tid=6472## JRE version: 6.0_43-b01# Java VM: Java HotSpot(TM) Client VM (20.14-b01 mixed mode windows-x86 )# Problematic frame:# C [ntvinv.dll+0x11790]## If you would like to submit a bug report, please visit:# http://java.sun.com/webapps/bugreport/crash.jsp# The crash happened outside the Java Virtual Machine in native code.# See problematic frame for where to report the bug.#--------------- T H R E A D ---------------Current thread (0x0262a800): JavaThread "main" [_thread_in_native, id=6472, stack(0x00430000,0x00480000)]siginfo: ExceptionCode=0xc0000005, reading address 0x00000000Registers:EAX=0x00000000, EBX=0x00000000, ECX=0xbc5bb6fa, EDX=0x0047f51cESP=0x0047f3ec, EBP=0x0047f644, ESI=0x0262a928, EDI=0x00000000EIP=0x7ce71790, EFLAGS=0x00010202Top of Stack: (sp=0x0047f3ec)0x0047f3ec: 14864e80 0262a928 14864e80 0047f6940x0047f3fc: 0047f6a4 0047f660 6a5c2e2e 625c65720x0047f40c: 6a5c6e69 2e747761 006c6c64 415c3a430x0047f41c: 49476372 65445c53 6f6c6576 4b7265700x0047f42c: 30317469 6a5c322e 5c617661 5c65726a0x0047f43c: 5c65726a 5c6e6962 7477616a 6c6c642e0x0047f44c: 00540000 005904d8 00000000 0262a8000x0047f45c: 0262b060 00000000 00000007 0047f554Instructions: (pc=0x7ce71790)0x7ce71770: 60 90 eb 7c 8b f8 85 ff 75 7a 53 e8 20 fd ff ff0x7ce71780: 8b d8 8d 94 24 30 01 00 00 2b d3 eb 03 8d 49 000x7ce71790: 8a 08 88 0c 02 40 84 c9 75 f6 8d 94 24 30 01 000x7ce717a0: 00 52 ff 15 60 90 eb 7c 53 8b f8 e8 88 3f 02 00Register to memory mapping:EAX=0x00000000 is an unknown valueEBX=0x00000000 is an unknown valueECX=0xbc5bb6fa is an unknown valueEDX=0x0047f51c is pointing into the stack for thread: 0x0262a800ESP=0x0047f3ec is pointing into the stack for thread: 0x0262a800EBP=0x0047f644 is pointing into the stack for thread: 0x0262a800ESI=0x0262a928 is an unknown valueEDI=0x00000000 is an unknown valueStack: [0x00430000,0x00480000], sp=0x0047f3ec, free space=316kNative frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)C [ntvinv.dll+0x11790] Java_com_esri_arcgis_system_EngineInitializer_initLicensing+0x1020Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)j com.esri.arcgis.interop.NativeObjRef.getJdk13WindowsHandleNative(Ljava/awt/Canvas
J+0j com.esri.arcgis.interop.NativeObjRef.a(Ljava/awt/Canvas
J+1j com.esri.arcgis.interop.r.getHandleForCanvas(Ljava/awt/Canvas
J+1j com.esri.arcgis.interop.Ocx.a()J+48j com.esri.arcgis.interop.Ocx.addNotify()V+94j com.esri.arcgis.controls.PageLayoutControl.addNotify()V+5j java.awt.Container.addNotify()V+61j javax.swing.JComponent.addNotify()V+1j java.awt.Container.addNotify()V+61j javax.swing.JComponent.addNotify()V+1j java.awt.Container.addNotify()V+61j javax.swing.JComponent.addNotify()V+1j java.awt.Container.addNotify()V+61j javax.swing.JComponent.addNotify()V+1j javax.swing.JRootPane.addNotify()V+1j java.awt.Container.addNotify()V+61j java.awt.Window.addNotify()V+73j java.awt.Frame.addNotify()V+70j java.awt.Window.show()V+8j java.awt.Component.show(Z)V+5j java.awt.Component.setVisible(Z)V+2j java.awt.Window.setVisible(Z)V+2j latitude.arcobjects.utils.MapWindow.setPageLayout(Lcom/esri/arcgis/carto/IPageLayout
V+51j latitude.arcobjects.proxy.PageProxy.startVisualMode(Lcom/esri/arcgis/geometry/IEnvelope
V+20j latitude.application.export.Export.main([Ljava/lang/String
V+2519v ~StubRoutines::call_stub--------------- P R O C E S S ---------------Java Threads: ( => current thread ) 0x192f5400 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=6220, stack(0x2b5d0000,0x2b620000)] 0x19352800 JavaThread "AWT-Shutdown" [_thread_blocked, id=5696, stack(0x21870000,0x218c0000)] 0x19252c00 JavaThread "Thread-3" daemon [_thread_in_native, id=6980, stack(0x1a7f0000,0x1a840000)] 0x19281000 JavaThread "J-Integra COM initialization thread (please don't touch)" daemon [_thread_blocked, id=468, stack(0x19710000,0x19760000)] 0x19280800 JavaThread "ArcGIS VisualBean Mode STA Thread" daemon [_thread_in_native, id=2652, stack(0x19680000,0x196d0000)] 0x1927f800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=6760, stack(0x195b0000,0x19600000)] 0x1927a800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=2632, stack(0x19490000,0x194e0000)] 0x0253f400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3088, stack(0x18cd0000,0x18d20000)] 0x0253c800 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=3256, stack(0x18c00000,0x18c50000)] 0x0253a400 JavaThread "JDWP Command Reader" daemon [_thread_in_native, id=5640, stack(0x18b60000,0x18bb0000)] 0x02534400 JavaThread "JDWP Event Helper Thread" daemon [_thread_blocked, id=976, stack(0x18b10000,0x18b60000)] 0x02532000 JavaThread "JDWP Transport Listener: dt_socket" daemon [_thread_blocked, id=700, stack(0x18a30000,0x18a80000)] 0x02528000 JavaThread "Attach Listener" daemon [_thread_blocked, id=6232, stack(0x188d0000,0x18920000)] 0x02524c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=6240, stack(0x18840000,0x18890000)] 0x024f5000 JavaThread "Finalizer" daemon [_thread_blocked, id=6616, stack(0x187b0000,0x18800000)] 0x024f3800 JavaThread "Reference Handler" daemon [_thread_blocked, id=6708, stack(0x18720000,0x18770000)]=>0x0262a800 JavaThread "main" [_thread_in_native, id=6472, stack(0x00430000,0x00480000)]Other Threads: 0x024ef000 VMThread [stack: 0x18690000,0x186e0000] [id=3836] 0x1917b800 WatcherThread [stack: 0x18d60000,0x18db0000] [id=3320]VM state:not at safepoint (normal execution)VM Mutex/Monitor currently owned by a thread: NoneHeapdef new generation total 4928K, used 3885K [0x04630000, 0x04b80000, 0x09b80000) eden space 4416K, 76% used [0x04630000, 0x0497d6f0, 0x04a80000) from space 512K, 98% used [0x04a80000, 0x04afe058, 0x04b00000) to space 512K, 0% used [0x04b00000, 0x04b00000, 0x04b80000)tenured generation total 10944K, used 2157K [0x09b80000, 0x0a630000, 0x14630000) the space 10944K, 19% used [0x09b80000, 0x09d9b5d8, 0x09d9b600, 0x0a630000)compacting perm gen total 16384K, used 16187K [0x14630000, 0x15630000, 0x18630000) the space 16384K, 98% used [0x14630000, 0x155fee48, 0x155ff000, 0x15630000)No shared spaces configured.Code Cache [0x02630000, 0x02798000, 0x04630000)total_blobs=721 nmethods=477 adapters=187 free_code_cache=32092160 largest_free_block=1216Dynamic libraries:0x00400000 - 0x00425000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\javaw.exe0x77240000 - 0x773c0000 C:\Windows\SysWOW64\ntdll.dll0x75ec0000 - 0x75fd0000 C:\Windows\syswow64\kernel32.dll0x76100000 - 0x76147000 C:\Windows\syswow64\KERNELBASE.dll0x76d00000 - 0x76da1000 C:\Windows\syswow64\ADVAPI32.dll0x76930000 - 0x769dc000 C:\Windows\syswow64\msvcrt.dll0x76520000 - 0x76539000 C:\Windows\SysWOW64\sechost.dll0x76bb0000 - 0x76ca0000 C:\Windows\syswow64\RPCRT4.dll0x74bc0000 - 0x74c20000 C:\Windows\syswow64\SspiCli.dll0x74bb0000 - 0x74bbc000 C:\Windows\syswow64\CRYPTBASE.dll0x75d70000 - 0x75e70000 C:\Windows\syswow64\USER32.dll0x75fd0000 - 0x76060000 C:\Windows\syswow64\GDI32.dll0x76150000 - 0x7615a000 C:\Windows\syswow64\LPK.dll0x76060000 - 0x760fd000 C:\Windows\syswow64\USP10.dll0x769f0000 - 0x76a50000 C:\Windows\system32\IMM32.DLL0x76540000 - 0x7660c000 C:\Windows\syswow64\MSCTF.dll0x7c340000 - 0x7c396000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\msvcr71.dll0x6d8c0000 - 0x6db70000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\client\jvm.dll0x70500000 - 0x70532000 C:\Windows\system32\WINMM.dll0x73790000 - 0x737dc000 C:\Windows\system32\apphelp.dll0x6d870000 - 0x6d87c000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\verify.dll0x6d3d0000 - 0x6d3ef000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\java.dll0x6d420000 - 0x6d449000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\jdwp.dll0x6d740000 - 0x6d746000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\npt.dll0x6d8b0000 - 0x6d8bf000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\zip.dll0x6d2b0000 - 0x6d2b7000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\dt_socket.dll0x75e80000 - 0x75eb5000 C:\Windows\syswow64\WS2_32.dll0x75e70000 - 0x75e76000 C:\Windows\syswow64\NSI.dll0x70b50000 - 0x70b60000 C:\Windows\system32\NLAapi.dll0x70b40000 - 0x70b50000 C:\Windows\system32\napinsp.dll0x70b20000 - 0x70b32000 C:\Windows\system32\pnrpnsp.dll0x70db0000 - 0x70dec000 C:\Windows\System32\mswsock.dll0x73800000 - 0x73844000 C:\Windows\system32\DNSAPI.dll0x70b10000 - 0x70b18000 C:\Windows\System32\winrnr.dll0x70ae0000 - 0x70b07000 C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL0x769e0000 - 0x769e5000 C:\Windows\syswow64\PSAPI.DLL0x762c0000 - 0x76317000 C:\Windows\syswow64\SHLWAPI.dll0x74520000 - 0x7453c000 C:\Windows\system32\IPHLPAPI.DLL0x74510000 - 0x74517000 C:\Windows\system32\WINNSI.DLL0x70aa0000 - 0x70ad8000 C:\Windows\System32\fwpuclnt.dll0x70a90000 - 0x70a96000 C:\Windows\system32\rasadhlp.dll0x70cb0000 - 0x70cb5000 C:\Windows\System32\wshtcpip.dll0x6d6b0000 - 0x6d6c3000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\net.dll0x70a80000 - 0x70a86000 C:\Windows\System32\wship6.dll0x6d0b0000 - 0x6d1fc000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\awt.dll0x74a80000 - 0x74ad1000 C:\Windows\system32\WINSPOOL.DRV0x76160000 - 0x762bc000 C:\Windows\syswow64\ole32.dll0x71000000 - 0x7119e000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18807_none_41e554362bd82458\COMCTL32.dll0x6f1f0000 - 0x6f203000 C:\Windows\system32\DWMAPI.DLL0x6ee30000 - 0x6eeb0000 C:\Windows\system32\uxtheme.dll0x6d2e0000 - 0x6d32f000 C:\ArcGIS\DeveloperKit10.2\java\jre\bin\fontmanager.dll0x7ce60000 - 0x7ced5000 C:\ArcGIS\Desktop10.2\bin\ntvinv.dll0x76db0000 - 0x76e3f000 C:\Windows\syswow64\OLEAUT32.dll0x76b20000 - 0x76ba3000 C:\Windows\syswow64\CLBCatQ.DLL0x71ea0000 - 0x71eb1000 C:\Program Files (x86)\Common Files\ArcGIS\bin\ArcGISVersion.dll0x64530000 - 0x6455b000 C:\Windows\WinSxS\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.7523_none_51c8dd18bbe8adec\ATL90.DLL0x644a0000 - 0x6452e000 C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.7523_none_508f21ccbcbbb7a8\MSVCP90.dll0x711a0000 - 0x71243000 C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.7523_none_508f21ccbcbbb7a8\MSVCR90.dll0x732f0000 - 0x73307000 C:\Windows\system32\CRYPTSP.dll0x731c0000 - 0x731fb000 C:\Windows\system32\rsaenh.dll0x73220000 - 0x7322e000 C:\Windows\system32\RpcRtRemote.dll0x617b0000 - 0x61987000 C:\ARCGIS\DESKTOP10.2\BIN\DADFLib.dll0x74ae0000 - 0x74ae9000 C:\Windows\system32\VERSION.dll0x74ff0000 - 0x75c3b000 C:\Windows\syswow64\SHELL32.dll0x64480000 - 0x64497000 C:\ARCGIS\DESKTOP10.2\BIN\AoInitializer.dll0x74a10000 - 0x74a20000 C:\ARCGIS\DESKTOP10.2\BIN\AppInitializerLib.dll0x61510000 - 0x617a2000 C:\ARCGIS\DESKTOP10.2\BIN\AfCore.dll0x70580000 - 0x70591000 C:\Windows\system32\NETAPI32.dll0x70570000 - 0x70579000 C:\Windows\system32\netutils.dll0x70550000 - 0x70569000 C:\Windows\system32\srvcli.dll0x70540000 - 0x7054f000 C:\Windows\system32\wkscli.dll0x704e0000 - 0x704f2000 C:\Windows\system32\MPR.dll0x74d70000 - 0x74deb000 C:\Windows\syswow64\COMDLG32.dll0x61060000 - 0x61501000 C:\ARCGIS\DESKTOP10.2\BIN\AfCore_libFNP.dll0x72d10000 - 0x72d19000 C:\Windows\system32\snmpapi.dll0x76320000 - 0x764bd000 C:\Windows\syswow64\SETUPAPI.dll0x76900000 - 0x76927000 C:\Windows\syswow64\CFGMGR32.dll0x76a70000 - 0x76a82000 C:\Windows\syswow64\DEVOBJ.dll0x74560000 - 0x74567000 C:\Windows\system32\WSOCK32.dll0x72be0000 - 0x72c1c000 C:\Windows\system32\OLEACC.dll0x6f140000 - 0x6f14a000 C:\Windows\system32\wbem\wbemprox.dll0x6f150000 - 0x6f1ac000 C:\Windows\system32\wbemcomn.dll0x6f050000 - 0x6f05f000 C:\Windows\system32\wbem\wbemsvc.dll0x6ef70000 - 0x6f006000 C:\Windows\system32\wbem\fastprox.dll0x6ef50000 - 0x6ef68000 C:\Windows\system32\NTDSAPI.dll0x76680000 - 0x766af000 C:\Windows\syswow64\WINTRUST.dll0x75c40000 - 0x75d61000 C:\Windows\syswow64\CRYPT32.dll0x766b0000 - 0x766bc000 C:\Windows\syswow64\MSASN1.dll0x728b0000 - 0x728b3000 C:\Windows\system32\icmp.Dll0x70b90000 - 0x70b9d000 C:\Windows\system32\dhcpcsvc6.DLL0x70b70000 - 0x70b82000 C:\Windows\system32\dhcpcsvc.DLL0x6d590000 - 0x6d5ac000 c:\arcgis\desktop10.2\bin\ccjw.dll0x60ed0000 - 0x61060000 C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18834_none_72d38c5186679d48\gdiplus.dll0x7e690000 - 0x7e69f000 c:\arcgis\desktop10.2\bin\reghelp.dll0x64390000 - 0x6447a000 C:\ARCGIS\DESKTOP10.2\BIN\BGLAPI.dll0x60e00000 - 0x60ec6000 C:\ARCGIS\DESKTOP10.2\BIN\BGLGeomChestLib.dll0x72830000 - 0x728a9000 C:\Windows\system32\mscms.dll0x76a50000 - 0x76a67000 C:\Windows\syswow64\USERENV.dll0x76670000 - 0x7667b000 C:\Windows\syswow64\profapi.dll0x7a130000 - 0x7a180000 C:\ARCGIS\DESKTOP10.2\BIN\LCMS117LIB.DLL0x60d20000 - 0x60df2000 C:\ARCGIS\DESKTOP10.2\BIN\BGLFontEngine.dll0x79540000 - 0x7965f000 C:\ARCGIS\DESKTOP10.2\BIN\icuuc44.dll0x781d0000 - 0x79011000 C:\ARCGIS\DESKTOP10.2\BIN\icudt44.dll0x79350000 - 0x79383000 C:\ARCGIS\DESKTOP10.2\BIN\icule44.dll0x64360000 - 0x6438f000 C:\ARCGIS\DESKTOP10.2\BIN\BGLAPILib.dll0x60c80000 - 0x60d1f000 C:\ARCGIS\DESKTOP10.2\BIN\ImageAccessLib.dll0x60be0000 - 0x60c73000 C:\ARCGIS\DESKTOP10.2\BIN\BGLRasterizerLib.dll0x79300000 - 0x7930f000 C:\ARCGIS\DESKTOP10.2\BIN\icuio44.dll0x79160000 - 0x792e5000 C:\ARCGIS\DESKTOP10.2\BIN\icuin44.dll0x73610000 - 0x73705000 C:\Windows\system32\propsys.dll0x74a50000 - 0x74a71000 C:\Windows\system32\ntmarta.dll0x76cb0000 - 0x76cf5000 C:\Windows\syswow64\WLDAP32.dll0x60b60000 - 0x60bd6000 C:\ARCGIS\DESKTOP10.2\BIN\BGLToGDIHelper.dll0x64330000 - 0x64358000 C:\ARCGIS\DESKTOP10.2\BIN\BGLSymbolsLib.dll0x60ab0000 - 0x60b5c000 C:\ARCGIS\DESKTOP10.2\BIN\BGLImageCoders.dll0x637f0000 - 0x63828000 C:\Windows\system32\icm32.dll0x60950000 - 0x60aa7000 C:\Windows\System32\msxml6.dll0x60900000 - 0x60944000 C:\ARCGIS\DESKTOP10.2\BIN\BGLCache.dll0x60620000 - 0x608f6000 C:\ARCGIS\DESKTOP10.2\BIN\Geometry.dll0x605f0000 - 0x60612000 C:\Windows\system32\GLU32.dll0x60520000 - 0x605e8000 C:\Windows\system32\OPENGL32.dll0x60430000 - 0x60517000 C:\Windows\system32\DDRAW.dll0x71de0000 - 0x71de6000 C:\Windows\system32\DCIMAN32.dll0x7d3a0000 - 0x7d79b000 C:\ARCGIS\DESKTOP10.2\BIN\pe.dll0x1c350000 - 0x1c3ad000 C:\ARCGIS\DESKTOP10.2\BIN\sg.dll0x60220000 - 0x60425000 C:\ARCGIS\DESKTOP10.2\BIN\ExtTopoEngine.dll0x1d060000 - 0x1d4be000 C:\ARCGIS\DESKTOP10.2\BIN\sde.dll0x6f3d0000 - 0x6f3df000 C:\Windows\system32\SAMCLI.DLLVM Arguments:jvm_args: -agentlib:jdwp=transport=dt_socket,suspend=y,address=localhost:49309 -Dfile.encoding=Cp1252java_command: latitude.application.export.ExportLauncher Type: SUN_STANDARDEnvironment Variables
ATH=C:\Python27\ArcGIS10.2\;C:\ARCGIS\DESKTOP10.2\BIN;C:\ArcGIS\DeveloperKit10.2\java\jre\bin;C:\PROGRA~2\Fiery\COMMAN~1\plugins;C:\PROGRA~2\COMMON~1\EFI;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Perl64\site\bin;C:\Perl64\bin;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\apache-maven-3.2.1\bin;C:\Program Files (x86)\Microsoft ASP.NET\ASP.NET Web Pages\v1.0\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.0\Windows Performance Toolkit\;C:\Program Files\nodejs\;C:\Python27\ArcGISx6410.2;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\Git\cmd;C:\Program Files (x86)\GeoConcept SA\GeoConcept;C:\Program Files (x86)\GeoConcept SA\GeoLib\Data;C:\Program Files (x86)\GeoConcept SA\GeoConcept;C:\Users\Kevin\AppData\Roaming\npm;C:\MinGW\bin;C:\Program Files (x86)\InkscapeUSERNAME=KevinOS=Windows_NTPROCESSOR_IDENTIFIER=Intel64 Family 6 Model 60 Stepping 3, GenuineIntel--------------- S Y S T E M ---------------OS: Windows 7 , 64 bit Build 7601 Service Pack 1CPU:total 8 (4 cores per cpu, 2 threads per core) family 6 model 60 stepping 3, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, htMemory: 4k page, physical 8322424k(5368132k free), swap 16643012k(13279444k free)vm_info: Java HotSpot(TM) Client VM (20.14-b01) for windows-x86 JRE (1.6.0_43-b01), built on Mar 1 2013 02:51:23 by "java_re" with MS VC++ 7.1 (VS2003)time: Wed Jun 10 11:52:47 2015elapsed time: 98 seconds
'Native Invocation Library for ArcGIS Java Interop'
