ESRI QueryLayer + Javascript API - map displays inconsistent results
We recently migrated one of our map services from FGDB to an SQL Server spatial db backend. We are noticing a problem now in that the map appears to display locations inconsistently. I created a JSFiddle to demonstrate the issue and to simplify the code as much as possible.
https://jsfiddle.net/acurtiss/pbuLot1g/22/
If you zoom in or out, or simply re-run the application, you should see that some zip codes will randomly go blank. (The zip codes on this map should be nearly 100% filled in.) I have checked the JSON object returned from the map service and verified that the results are consistent and correct, so I'm beginning to suspect a problem withe the Javascript API itself. I have contacted ESRI support and have a ticket open with them, but so far they haven't identified the source of the problem so I thought I would open this up to a broader set of GIS experts here on stack exchange.
Thanks for whatever guidance or suggestions you can provide!
Aaron
