I need to build grass-7.0.1 for qgis on Windows 10 with Msys/MinGW. I succefully installed all packages from general and several packages from optional requirements. Here is my configure options (minimal):
./configure \--prefix=/usr/local \--enable-shared \--disable-static \--enable-largefile \--disable-x11 \--with-cxx \--with-proj-share=/usr/local/share/proj \--without-gdal \--without-x \--without-sqlite \--without-postgres \--disable-doc \--without-freetype \--without-cairo \--without-tiff \--without-png \--without-opengl \--without-fftw \--without-regexThen I wait about 15 minutes while compiling and get this message:
In case of errors please change into the directory with error and run 'make'.If you get multiple errors, you need to deal with them in the order theyappear in the error log. If you get an error building a library, you willalso get errors from anything which uses the library.Grass Makefiles contains complex referencing and it's too expensive to try fix the problems one by one. Maybe any ideas?
