Error while installing Windshaft-cartodb
I am setting cartoDB locally in ubuntu 12.04 by following https://github.com/danseely/cartodb-install/blob/master/DEV-INSTALLATION.md. And while installing Windshaft-cartodb there are some errors logged in npm-debug.log file. And below is the error in the log file
42454 info postuninstall windshaft@1.0.142455 error mapnik@1.4.15-cdb2 install: node-pre-gyp install --fallback- to-build42455 error Exit status 142456 error Failed at the mapnik@1.4.15-cdb2 install script.42456 error This is most likely a problem with the mapnik package,42456 error not with npm itself.42456 error Tell the author that this fails on your system:42456 error node-pre-gyp install --fallback-to-build42456 error You can get their info via:42456 error npm owner ls mapnik42456 error There is likely additional logging output above.42457 error System Linux 3.2.0-23-generic-pae42458 error command "/usr/bin/node" "/usr/bin/npm" "install"42459 error cwd /home/user/Windshaft-cartodb42460 error node -v v0.10.2642461 error npm -v 1.4.342462 error code ELIFECYCLE42463 verbose exit [ 1, true ]
