Error when trying to bind popup on geojson, failed to execute 'appendChild'
I'm trying to load more than 13 thousand points in leaflet from a geoJson file, everything seems to work just fine except the Popup function. I've looked everywhere for a solution and most answers out here do not work in my case. Here is an excerpt of my code:
//calling the geoJSON var SaoPaulo = L.geoJson(SP_ResSinglePoint, { pointToLayer: function (feature, latlng) { var popupContent = feature.properties.Time; console.log(popupContent); return L.circleMarker(latlng, Style(feature)).bindPopup(popupContent); }, });When I click on a given point I get the following message on the console:
Uncaught TypeError: Failed to execute 'appendChild' on 'Node': parameter 1 is not of type 'Node'.But I do get all the info I'm looking for through the console.log so I'm assuming that that my popup parameters are correct, but yet no luck in the map. Any help or advice is much appreciated!
Best,
