I have a table in PostGIS (2.1.7) containing adjacent multipolygons, and I'd like to create a view containing polygons which are merged versions of the multipolygons based on some field value.
I tried the following query:
CREATE VIEW results ASSELECT somefield, ST_Union(geom)::geometry(Polygon, 2056) AS geom FROM somelayer GROUP BY somefield;and I got the following error:
CREATE VIEW results AS SELECT somefield, ST_Union(geom)::geometry(MultiPolygon, 2056) AS geom FROM somelayer GROUP BY somefield;But it didn't help since I got the following error:
CREATE VIEW results AS SELECT somefield, ST_Multi(ST_Union(geom))::geometry(MultiPolygon, 2056) AS geom FROM somelayer GROUP BY somefield;How can I get the desired results? Thanks a lot!
Geometry type (MultiPolygon) does not match column type (Polygon)
I thus tried to change the result type to multipolygon:
Geometry type (Polygon) does not match column type (MultiPolygon)
The following query finally worked but it is not optimal since I'd like to have polygons instead of multipolygons (it should be possible since the resulting polygons are all singlepart):
