When I try to run the R script "Summary statistics" in QGIS 2.12.1 on a Windows 7/64 bit machine, I get the error message "error in if (!file.info(DSN)$isdir) DSN missing value where TRUE/FALSE needed," and the output file is empty.
Having read a comment that R doesn't work properly if installed in the c:\Program Files\ directory, I tried installing it in its own directory in c:, but that didn't make any difference. I've tried installing R with and without the 32 bit files, and with just the 32 bit files (no 64 bit files), but the result is always the same: no results. The same happens with the R Histogram script.
QGIS's native Basic Statistics routine does produce results. Can anyone help me get R scripts working in QGIS?
Thank you, Terry
Thank you, Terry
