I have a raster file in ESRI ArcGrid format (e.g. hdr.adf). I would like to run some analysis using GeoTools. I've never used the coverage classes before and I'm having a few problems out of the gates.
I can instantiate the AIGReader just fine and I get the correct values when I check the bounds. Example:
BaseGDALGridCoverage2DReader reader = new AIGReader(file); System.out.println(reader.getSource()); for (String coverage : reader.getGridCoverageNames()){ System.out.println(coverage); } System.out.println(reader.getOriginalEnvelope()); System.out.println(reader.getOriginalGridRange()); System.out.println(reader.getCoordinateReferenceSystem());This is the stdout:
Jan 06, 2015 6:38:09 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL INFO: GDAL Native Library loaded (version: 1.11.1) Jan 06, 2015 6:38:09 PM org.geotools.coverageio.gdal.BaseGDALGridCoverage2DReader setCoverageProperties INFO: crs not found, proceeding with default crs K:\Landscan\LandScan_Archive_2000_2012\LandScan2000\lspop2000\hdr.adf geotools_coverage GeneralEnvelope[(-180.0, -90.0), (179.99999999999858, 85.99999999999929)] GridEnvelope2D[0..43199, 0..21119] LOCAL_CS["Wildcard 2D cartesian plane in metric unit", LOCAL_DATUM["Unknown", 0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","404000"]]When I call the BaseGDALGridCoverage2DReader.read() method, I get a null pointer exception:
GridCoverage2D gc = (GridCoverage2D) reader.read(null); The read method throws the following Exception:
Exception in thread "main" java.lang.NullPointerException at org.geotools.coverageio.RasterLayerRequest.setBaseParameters(RasterLayerRequest.java:902) at org.geotools.coverageio.RasterLayerRequest.(RasterLayerRequest.java:206) at org.geotools.coverageio.BaseGridCoverage2DReader.read(BaseGridCoverage2DReader.java:400)I tried passing in an array of GeneralParameterValue but I still get a null pointer exception. Example:
ParameterValue policy = AbstractGridFormat.OVERVIEW_POLICY.createValue(); policy.setValue(OverviewPolicy.IGNORE); ParameterValue gridsize = AbstractGridFormat.SUGGESTED_TILE_SIZE.createValue(); ParameterValue useJaiRead = AbstractGridFormat.USE_JAI_IMAGEREAD.createValue(); useJaiRead.setValue(true); reader.read(new GeneralParameterValue[]{policy, gridsize, useJaiRead});I'm using Java 1.6 so I'm stuck with GeoTools 10.8.
Any suggestions?
UPDATE
QGIS and GDAL can open the file just file. Here's a rendering from QGIS.
Here's the output from gdalinfo. As you can see the projection is not set. I hope this isn't the cause. If it is, is there a way to tell the reader which projection to use?
Driver: AIG/Arc/Info Binary GridFiles: K:\Landscan\LandScan_Archive_2000_2012\LandScan2000\lspop2000 K:\Landscan\LandScan_Archive_2000_2012\LandScan2000\lspop2000.aux.xml K:\Landscan\LandScan_Archive_2000_2012\LandScan2000\lspop2000\dblbnd.adf K:\Landscan\LandScan_Archive_2000_2012\LandScan2000\lspop2000\hdr.adf K:\Landscan\LandScan_Archive_2000_2012\LandScan2000\lspop2000\log K:\Landscan\LandScan_Archive_2000_2012\LandScan2000\lspop2000\metadata.xml K:\Landscan\LandScan_Archive_2000_2012\LandScan2000\lspop2000\sta.adf K:\Landscan\LandScan_Archive_2000_2012\LandScan2000\lspop2000\vat.adf K:\Landscan\LandScan_Archive_2000_2012\LandScan2000\lspop2000\w001001.adf K:\Landscan\LandScan_Archive_2000_2012\LandScan2000\lspop2000\w001001x.adfSize is 43200, 21120Coordinate System is `'Origin = (-180.000000000000000,85.999999999999289)Pixel Size = (0.008333333333333,-0.008333333333333)Corner Coordinates:Upper Left (-180.0000000, 86.0000000)Lower Left (-180.0000000, -90.0000000)Upper Right ( 180.0000000, 86.0000000)Lower Right ( 180.0000000, -90.0000000)Center ( -0.0000000, -2.0000000)Band 1 Block=256x4 Type=Int32, ColorInterp=Undefined Description = lspop2000 Min=0.000 Max=159004.000 Minimum=0.000, Maximum=35453.000, Mean=14.586, StdDev=221.326 NoData Value=-2147483647 Metadata: LAYER_TYPE=athematic STATISTICS_MAXIMUM=35453 STATISTICS_MEAN=14.58631887449 STATISTICS_MINIMUM=0 STATISTICS_STDDEV=221.32624697214
Any suggestions?
UPDATE
