Error: "name" and "value" are required for setHeader()
Upon setting up my dev environment as instructed Here, I am getting this error message:
Error: "name" and "value" are required for setHeader().at ServerResponse.OutgoingMessage.setHeader (_http_outgoing.js:333:11)at ServerResponse.res.setHeader (/Users/ians/code/cmv-app/node_modules/grunt-contrib-connect/node_modules/connect/lib/patch.js:63:22)at Object.enableCORS [as handle] (/Users/ians/code/cmv-app/Gruntfile.js:10:11)at next (/Users/ians/code/cmv-app/node_modules/grunt-contrib-connect/node_modules/connect/lib/proto.js:193:15)at Object.json [as handle] (/Users/ians/code/cmv-app/node_modules/grunt-contrib-connect/node_modules/connect/lib/middleware/json.js:42:37)at next (/Users/ians/code/cmv-app/node_modules/grunt-contrib-connect/node_modules/connect/lib/proto.js:193:15)at Object.urlencoded [as handle] (/Users/ians/code/cmv-app/node_modules/grunt-contrib-connect/node_modules/connect/lib/middleware/urlencoded.js:40:37)at next (/Users/ians/code/cmv-app/node_modules/grunt-contrib-connect/node_modules/connect/lib/proto.js:193:15)at Function.app.handle (/Users/ians/code/cmv-app/node_modules/grunt-contrib-connect/node_modules/connect/lib/proto.js:201:3)at Server.app (/Users/ians/code/cmv-app/node_modules/grunt-contrib-connect/node_modules/connect/lib/connect.js:65:37)Was wondering if anyone else has come across this issue or may know the cause.
