Error in: org.geotools.swing.MapLayerTableCellRenderer.getLi stCellRendererComponent
Getting this error while exporting an shapefile to svg (courtesy to iant):
The weird thing is I wasn't getting this error before, but I just suddenly starting getting it after running my application, what could have happened?
Code can be found here: Exporting Shapefile to SVG using Java & GeoTools?
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerExceptionat org.geotools.swing.MapLayerTableCellRenderer.getListCellRendererComponent(MapLayerTableCellRenderer.java:259)at javax.swing.plaf.basic.BasicListUI.paintCell(BasicListUI.java:208)at javax.swing.plaf.basic.BasicListUI.paintImpl(BasicListUI.java:317)at javax.swing.plaf.basic.BasicListUI.paint(BasicListUI.java:240)at javax.swing.plaf.ComponentUI.update(ComponentUI.java:161)at javax.swing.JComponent.paintComponent(JComponent.java:779)at javax.swing.JComponent.paint(JComponent.java:1055)at javax.swing.JComponent.paintChildren(JComponent.java:888)at javax.swing.JComponent.paint(JComponent.java:1064)at javax.swing.JViewport.paint(JViewport.java:731)at javax.swing.JComponent.paintChildren(JComponent.java:888)at javax.swing.JComponent.paint(JComponent.java:1064)at javax.swing.JComponent.paintToOffscreen(JComponent.java:5232)at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1529)at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1452)at javax.swing.RepaintManager.paint(RepaintManager.java:1249)at javax.swing.JComponent._paintImmediately(JComponent.java:5180)at javax.swing.JComponent.paintImmediately(JComponent.java:4991)at javax.swing.RepaintManager$3.run(RepaintManager.java:808)at javax.swing.RepaintManager$3.run(RepaintManager.java:796)at java.security.AccessController.doPrivileged(Native Method)at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:796)at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:769)at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:718)at javax.swing.RepaintManager.access$1100(RepaintManager.java:62)at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1677)at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:312)at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:745)at java.awt.EventQueue.access$300(EventQueue.java:103)at java.awt.EventQueue$3.run(EventQueue.java:706)at java.awt.EventQueue$3.run(EventQueue.java:704)at java.security.AccessController.doPrivileged(Native Method)at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)at java.awt.EventQueue.dispatchEvent(EventQueue.java:715)at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
