I am following this tutorial to build QGIS from source.The CMAKE dump is as below. Please help.
-- QGIS version: 2.8.3 Wien (20803)-- Found GRASS: c:/OSGeo4W/apps/grass/grass-6.4.4 (6.4.4)-- Found Proj: C:/OSGeo4W/lib/proj_i.lib-- Found GEOS: C:/OSGeo4W/lib/geos_c.lib (3.4.2)-- Found GDAL: C:/OSGeo4W/lib/gdal_i.lib (1.11.2)-- Found Expat: C:/OSGeo4W/lib/libexpat.lib-- Found Spatialindex: C:/OSGeo4W/lib/spatialindex_i.lib-- Found Qwt: C:/OSGeo4W/lib/qwt.lib (5.2.1)-- Found Sqlite3: C:/OSGeo4W/lib/sqlite3_i.lib-- Found PostgreSQL: C:/OSGeo4W/lib/libpq.lib-- Found SpatiaLite: C:/OSGeo4W/lib/spatialite_i.lib-- Found Qt version: 4.8.6-- Touch support disabled-- Found QScintilla2: C:/OSGeo4W/lib/qscintilla2.lib (2.8.4)-- Pedantic compiler settings enabled-- Found Python executable: C:/OSGeo4W/bin/python.exe-- Found Python version: 2.7.4-- Found Python library: C:/OSGeo4W/apps/Python27/libs/python27.lib-- Found SIP version: 4.16.5-- Found PyQt4 version: 4.11.3-- Found QScintilla2 PyQt4 module: 2.8.4-- Found QwtPolar: C:/OSGeo4W/lib/qwt.lib-- Found GSL: C:/OSGeo4W/lib/gsl.lib;C:/OSGeo4W/lib/cblas.lib-- txt2tags not found - disabledCMake Warning (dev) at cmake/SIPMacros.cmake:131 (GET_TARGET_PROPERTY): Policy CMP0026 is not set: Disallow use of the LOCATION target property. Run "cmake --help-policy CMP0026" for policy details. Use the cmake_policy command to set the policy and suppress this warning. The LOCATION property should not be read from target "python_module_qgis__core". Use the target name directly with add_custom_command, or use the generator expression $, as appropriate.Call Stack (most recent call first): python/CMakeLists.txt:141 (ADD_SIP_PYTHON_MODULE)This warning is for project developers. Use -Wno-dev to suppress it.
