I am stuck with a code due to a RunTimeError: Object: Error in Executing tooland I really can't find the mistake.The code is
Now, the script for "Adding Surface Info" to the network, using the raster with MAX MEAN defined just above
Set the raster of input, on the basis of the MAX MEAN
inSurface = "C:/B3061239/!!! WORK !!!/RAS_for_maxmean/", NameRasList[MEANlist.index(max(MEANlist))]
NOTE that NameRasList[MEANlist.index(max(MEANlist)) has been calculate before
method = "BILINEAR"if inSurface: print "Got inSurface"
Create list of feature classes
fcList = arcpy.ListFeatureClasses()print str(len(fcList))
Process: Add Surface Information
if fcList: print "Got featureclasses" for fc in fcList: desc = arcpy.Describe(fc) print desc.name # Determine if the feature is 2D #if not desc.hasZ: #if desc.shapeType == "Polygon": # Desired properties separated by semi-colons #Prop = "Z_MIN;Z_MAX" #elif desc.shapeType == "Point": #Prop = "Z" #elif desc.shapeType == "Multipoint": #Prop = "Z_MIN;Z_MAX;Z_MEAN" #elif desc.shapeType == "Polyline": #Prop = "LENGTH_3D" # Execute AddSurfaceInformation arcpy.ddd.AddSurfaceInformation(fc, inSurface, "Z_MAX", method, "", "1", "0", "NO_FILTER")
print "Completed adding surface information."Thank you very much in advance!
