Error during upgrade geodatabase SDE 9.2/Oracle 10 R2
I have an old sde/9.2 geodatabase built on Oracle 10 R2 with multiple geodatabases in users schemas and try to upgrade to sde/9.3.1.
I successfully upgraded the master SDE schema.
Now when I try to upgrade the geodatabase in schema named 'John' I receive the following error:
[Wed Oct 07 14:21:53 2015]
ST_Geometry Schema Owner: (SDE) Type Release: 1007
[Wed Oct 07 14:21:53 2015] Instance initialized for ((John)) . . .
[Wed Oct 07 14:21:53 2015] ArcSde is already at an acceptable release:
9.3.1
[Wed Oct 07 14:21:53 2015] S_insert_update_server_config_table():
Error insert data to server_config table.
[Wed Oct 07 14:21:53 2015] Error inserting following data into Server Config table:
Property name: CONNECTIONS
Numeric property value : 64
[Wed Oct 07 14:21:53 2015] ERROR in upgrading server_config table.
Error: -51
[Wed Oct 07 14:21:53 2015] DBMS error code: 6550
ORA-06550: Line 1 , Column 26 :
PLS-00201: identifier 'JOHN.SVR_CONFIG_UTIL' must be declared
PL/SQL: Statement ignored
ORA-06550: Line 1 , Column 132 :
PLS-00201: identifier 'JOHN.SDE_UTIL' must be declared
ORA-06550: Line 1 , Column 119 :
Property name C failed to load,
[Wed Oct 07 14:21:53 2015] with Property value: 64
[Wed Oct 07 14:21:53 2015] SDE release upgrade not completed(-1).
[Wed Oct 07 14:21:53 2015] ERROR installing/upgrading ArcSDE, Error = -1
Notes:
  • server_config table exist in SDE schema and has property CONNECTIONS = 48
  • There is SDE.SVR_CONFIG_UTIL and SDE.SDE_UTIL packages in SDE schema but not in John one.
Am I doing something wrong?
