Error during Manually building a tile server
I was following the entire process found here: https://switch2osm.org/serving-tiles/manually-building-a-tile-server-14-04/
I have an error though on Testing your tileserver part where i run the following commands
sudo -u username renderd -f -c /usr/local/etc/renderd.confEncountered this error: renderd[6166]: An error occurred while loading the map layer 'default': Could not create datasource. Required parameter 'type' is missing encountered during parsing of layer 'land-low' in Layer at line 48 of '/usr/local/share/maps/style/OSMBright/OSMBright.xml'
What have I missed?
Edit: Here are the lines in OSMBright.xml, the first line here is line 46 so line 48 is the line with srs
land-low
