I wrote the following code using QGIS'API.
import os from qgis.core import * import qgis.utils prefix_path = os.environ['QGIS_PREFIX_PATH'] QgsApplication.setPrefixPath(prefix_path, True) QgsApplication.initQgis() app = QgsApplication([], True) import processing from processing import * class DummyInterface(object): def __init__(self): self.destCrs = None def __getattr__(self, *args, **kwargs): def dummy(*args, **kwargs): return DummyInterface() return dummy def __iter__(self): return self def next(self): raise StopIteration def layers(self): # simulate iface.legendInterface().layers() return qgis.core.QgsMapLayerRegistry.instance().mapLayers().values() iface = DummyInterface() plugin = processing.classFactory(iface) uri = "file:///C:\Users\Tabrez\Desktop\importPoint.csv?crs=epsg:4326&delimiter=%s&xField=%s&yField=%s" % (",", "lon", "lat") layer = QgsVectorLayer(uri, "importPoints", "delimitedtext") layer1 = iface.addVectorLayer(uri, "importPoints", "delimitedtext") extent = layer.extent() xmin = extent.xMinimum() xmax = extent.xMaximum() ymin = extent.yMinimum() ymax = extent.yMaximum() outputExtent = str(xmin) + "," + str(xmax) + "," + str(ymin) + "," + str(ymax) radius = 0.05 cellSize = 0.005 print cellSize processing.runandload("saga:kerneldensityestimation", layer, "weightage", radius, 0, outputExtent, cellSize, "D:/test/raster.tif") iter = layer.getFeatures() pointCount = len(list(iter)) probabilityFailure = [[0.846], [0.846, 0.846], [0.28, 0.50, 0.72], [0.21, 0.39, 0.61, 0.79], [0.17, 0.32, 0.50, 0.68, 0.83], [0.14, 0.27, 0.42, 0.58, 0.73, 0.86], [0.12, 0.23, 0.36, 0.50, 0.64, 0.77, 0.88], [0.10, 0.20, 0.32, 0.44, 0.56, 0.68, 0.80, 0.90], [0.09, 0.18, 0.28, 0.39, 0.50, 0.61, 0.72, 0.82, 0.91], [0.08, 0.16, 0.26, 0.35, 0.45, 0.55, 0.65, 0.74, 0.84, 0.92], [0.07, 0.15, 0.23, 0.32, 0.41, 0.50, 0.59, 0.68, 0.77, 0.85, 0.93]] for i in probabilityFailure: print i os.system("gdal_contour -a 0.21 -fl 0.01 " + " D:/test/raster.tif " + " " + "D:/test/contour") QgsApplication.exitQgis() This line is giving me error:
processing.runandload("saga:kerneldensityestimation", layer, "weightage", radius, 0, outputExtent, cellSize, "D:/test/raster.tif") I am very new to python and QGIS. Please help.
