ERROR 000840: The value is not a Raster|Raster Catalog|Mosaic Layer from arcpy.AddJoi
I am doing some arcpy -functions and afterwards I'm trying to add the calculated results from one table to another table. I'm using the arcpy.AddJoin_management() function.
As input table I'm using a table which is stored in a personal geodatabase. The personal geodatabase is not the workspace environment! As "JoinTable" a Table of a file geodatabase is used. This file geodatabase is the workspace geodatabase environment.
The initialized function looks like this:
(%self.getWorkspaceEnvironment => "W:/a18fb/data/mypersonalgeodatabase.mdb" and tFactsheetHochwasser => table in the personal geodatabase)
arcpy.AddJoin_management("%s/tFactsheetHochwasser"%self.getWorkspaceEnvironment(),"KPG","GebaeudeKtn_BWVred1Stat","KPG","KEEP_ALL")
If the code is executed the following error-message appears:
Failed to execute.Parameters are not valid.The value cannot be a table
ERROR 000840: The value is not a Raster Layer.
ERROR 000840: The value is not a Raster Catalog Layer.
ERROR 000840: The value is not a Mosaic Layer.
Failed to execute (AddJoin)`.
