I'm consistently getting an error 000725 (Output Feature Class already exists) when trying to use the "points to line" tool in ArcMap 10.3
It's a points shapefile with 4 points and I just want to make them into a square outline. I've used this tool before and gotten this error, then rebooted my computer and it worked perfectly for multiple files for this exact same function. No luck this time.
I've rebooted, I've checked the "overwrite outputs" option under Geoprocessing options, I've created a new File Geodatabase in case the problem was that my default geodatabase was full. Now it's writing to a blank geodatabase, and being told to overwrite files, and STILL giving me the error that the file already exists. I've re-ordered my points within the shapefile to make sure they are in the correct order, I've tried converting my data to a shapefile through multiple avenues... I can't think of any other reason I'm getting this error.
