Elevation profile geoprocessing service - error 000840
I am trying to create an Elevation Profile service using the Python code found on the Setting up an on-premise elevation Profile service page:
And I followed all the instructions. I am able to run the tool with no errors in ArcGIS and I can publish the geoprocessing service, but when I run the gp service inside ArcGIS I get an error saying:
Error executing tool.: Failed to execute. Parameters are not valid. ERROR 000840: The value is not a TIN Layer. ERROR 000840: The value is not a Raster Layer. ERROR 000840: The value is not a Terrain Layer.ERROR 000840: The value is not a LAS Dataset Layer. Failed to execute (InterpolateShape). Failed to execute. Parameters are not valid. ERROR 000840: The value is not a TIN Layer. ERROR 000840: The value is not a Raster Layer. ERROR 000840: The value is not a Terrain Layer. ERROR 000840: The value is not a LAS Dataset Layer. Failed to execute (InterpolateShape). Failed to execute (Profile). Failed to execute (Profile).The problem seems to be in the Interpolate Shape analysis in line 307 in the Profile Tool.py but I am not sure what is wrong with it. Do you guys have any ideas?
