Dojo Promise/All Array Not Populating InfoTemplate in ArcGIS Javascript
Using dojo/promise/all I'm attempting to populate an infoTemplate with results from a queryTask which runs later in the script.
Our app returns an XY value from a geocoded address search and queries that value to see if it falls within a series of polygonal features. If it does it should pass a string for each of the three queries.
The query runs and the console doesn't log an error. However, the infoTemplate is blank
I've tried to loop through the array results prior to instantiating the infoTemplate but I don't know that that's necessary. Also, I've found that I'm unable to manually set the title of the InfoTemplate using a string.
Code for adding graphic/calling array:
function addPlaceGraphic(item, symbol) { map.graphics.clear(); var place = {}; var attributes, infoTemplate, pt, graphic; pt = item.feature.geometry; place.address = item.name; place.score = item.feature.attributes.score; var trashQuery = runPWQuery(pt, trashLayer, "trash"); var yardQuery = runPWQuery(pt, yardWasteLayer, "yardwaste"); var recycleQuery = runPWQuery(pt, recyclingLayer, "recycling"); all([trashQuery, yardQuery, recycleQuery]).then(function (results) { //receive query responses, update attributes and add graphics attributes = { trashQuery: pt.trashLayer, recycleQuery: pt.recyclingLayer, yardQuery: pt.yardWasteLayer }; infoTemplate = new InfoTemplate(); infoTemplate.setTitle("Scheduling Information"); infoTemplate.setContent("Trash: ${trashQuery}
Recycling: ${recycleQuery}
Mixed Bulk: ${yardQuery}"); graphic = new Graphic(pt, symbol, attributes, infoTemplate); //add to map map.graphics.add(graphic); map.centerAt(pt); }); }Code later in script for queryTask/returning promise:
function runPWQuery(in_geometry , in_fl , in_container_id) { var query = new esri.tasks.Query(); query.returnGeometry = true; query.outFields = ["*"]; query.geometry = in_geometry; var promise = in_fl.queryFeatures(query, function(myresponse, io) { var temp_val; var values = []; var tstr; for (var il = 0; il < myresponse.features.length; il++) { if (myresponse.features[il].attributes["MONDAY"] == "Yes") { temp_val = "Monday"; } else if (myresponse.features[il].attributes["TUESDAY"] == "Yes") { temp_val = "Tuesday"; } else if (myresponse.features[il].attributes["WEDNESDAY"] == "Yes") { temp_val = "Wednesday"; } else if (myresponse.features[il].attributes["THURSDAY"] == "Yes") { temp_val = "Thursday"; } else if (myresponse.features[il].attributes["FRIDAY"] == "Yes") { temp_val = "Friday"; } else { //temp_val = "Other"; temp_val = myresponse.features[il].attributes["DESCRIPT"]; } } var statCount = myresponse.features.length; if (statCount >= 1) { $("#" + in_container_id).html(temp_val); } else { $("#" + in_container_id).html(""); } return temp_val; }, function (error) { console.log(dojo.toJson(error, true)); }); //return promise return promise; } function renderPWQuery() { }
