Does the Postgis UpdateGeometrySRID function update the column structure as well as t
I had to manually insert a geometry from a shapefile which had SRID 0, and my column had SRID 4326, so I had to use the UpdateGeometrySRID function to update my column to SRID 0. I inserted the geometry and it worked fine, but now I need to transform everything back to SRID 4326, the column as well as the data inside it. Does UpdateGeometrySRID do that?
Additional question: how can I transform the geometry's SRID before inserting so that I don't have to modify my column?
