Disable feature popup when creating new simple marker
I have a leaflet map with some loaded polygon layers.When using the Simple Markers plugin, i would like to create a new marker on top of an already existing polygon feature, but i can only click the feature (which brings up the popup with information) and not place the marker on top of the feature. It works fine on an empty piece of the map.
Is it possible to disable the feature popup when the Simple Marker function is running?
L.Control.SimpleMarkers = L.Control.extend({ options: { position: 'topleft' }, onAdd: function () { var marker_container = L.DomUtil.create('div', 'marker_controls'); var add_marker_div = L.DomUtil.create('div', 'add_marker_control', marker_container); add_marker_div.id = 'add_marker_div_id'; add_marker_div.title = 'Add a new Note'; L.DomEvent.addListener(add_marker_div, 'click', L.DomEvent.stopPropagation) .addListener(add_marker_div, 'click', L.DomEvent.preventDefault) .addListener(add_marker_div, 'click', (function () { this.enterAddMarkerMode() }).bind(this)); return marker_container; }, enterAddMarkerMode: function () { if (markerList !== '') { for (var marker = 0; marker < markerList.length; marker++) { if (typeof(markerList[marker]) !== 'undefined') { markerList[marker].removeEventListener('click', this.onMarkerClickDelete); } } } document.getElementById('map').style.cursor = 'crosshair'; document.getElementById('add_marker_div_id').style.backgroundColor = '#b0c4de'; map.addEventListener('click', this.onMapClickAddMarker); }, onMapClickAddMarker: function (e) { map.removeEventListener('click'); document.getElementById('map').style.cursor = 'auto'; document.getElementById('add_marker_div_id').style.backgroundColor = '#FFF'; var popupContent = "You added a note on the map at " + e.latlng.toString(); var the_popup = L.popup({maxWidth: 160, closeButton: false}); the_popup.setContent(popupContent); var marker = L.marker(e.latlng); marker.addTo(map); marker.bindPopup(the_popup).openPopup(); markerList.push(marker); return false; },});var markerList = [];
