I want to do some checking if my point lies in any of the polygons defined in shapefile. So, I thought that I will determine CRS from shapefile (created in QGIS), and use it for transformation (where source CRS is EPSG:4326). My shapefile has geometry in EPSG:3857 (WGS-87 pseudo mercator). However, when I get CRS programatically from shapefile such way (lets assume that featureSource is non null FeatureSource type object):
CoordinateReferenceSystem crs = featureSource.getSchema().getCoordinateReferenceSystem();
This result: PROJCS["WGS_84_Pseudo_Mercator", GEOGCS["GCS_WGS_1984", DATUM["D_WGS_1984", SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295], AXIS["Longitude", EAST], AXIS["Latitude", NORTH]], PROJECTION["Mercator_2SP"], PARAMETER["standard_parallel_1", 0.0], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH]]
And when I check WKT definition of this CRS, it indeed is WGS87 pseudo mercator, but it is different from definition which I get that way:
CoordinateReferenceSystem crs = CRS.decode( "EPSG:3857" );
The result: PROJCS["WGS 84 / Pseudo-Mercator", GEOGCS["WGS 84", DATUM["World Geodetic System 1984", SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]], PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295], AXIS["Geodetic latitude", NORTH], AXIS["Geodetic longitude", EAST], AUTHORITY["EPSG","4326"]], PROJECTION["Popular Visualisation Pseudo Mercator", AUTHORITY["EPSG","1024"]], PARAMETER["semi_minor", 6378137.0], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["Easting", EAST], AXIS["Northing", NORTH], AUTHORITY["EPSG","3857"]]
I assume that QGIS has different definition of it. What is also weird that if I use definition from the shapefile, my transformed geometry has incorrect coordinates, and if I use the one from geotools, coordinates are computed correctly.
But still, the question is, is geotools able to correctly determine CRS which is used with given shapefile? I know that QGIS is different story, but do you know what these differences come from?
