Differences between columns in MapInfo
I have two columns in a nodes table, one column has the ground level of the node taken from the model and the other column has the ground level inferred from LiDAR. Is there a query that can be used to select records where one column is greater than the other by a certain value (eg 0.5m).
Thanks,
Callum
