Difference between Identify task & Attribute Info in ArcGIS API for JavaScript?
I am confused about the difference between Identify task and attribute info task.
According to research, both are displaying attribute information
  1. Interestingly if one point contains multiple attribute then Identify task shows multiple records while Attribute window display only single record
  2. Identify task displays the information if record is hidden in certain cases while Attribute window not.
  3. If you are using Dynamic layers in ArcGIS Java Script API (ver. 2.x & 3.x) then you cannot use Attribute window option while identify task works for both (i.e. feature layer and Dynamic layer)
So what exactly difference between them? & which is recommended?
