I am working with osmconverter to convert osm files(*.osm) to *.pbf, then i use osm2po to get sql file that run into PostGis to get a network table. The last step is to run a createTopology statement in SQL PostGis Editor to get the vertices of network. However this proccess only creates the initial and final nodes of a network stretch intersection and i would like to add more nodes between initial and final ones. Editting the osm2po.config file of osm2po could be a posibility?.Thank you very much.
