Recently was doing some work on an old layer and found that when I selected one point, or used the identify tool I was returning SEVEN points when it should just be one! I am currently using an ArcGIS 10.1 and have access to both Editor and Info licenses.
Is there an easy way to delete these duplicates via python, or another tool? The ObjectIDs are different but the values contained in other fields are the same. Therefore I think looking at intersecting geometry would be the best option There is probably easily over 2000 points with duplicates.
Thanks.
Thanks.
