Defining Projection Lambert Conformal Conical w custom GCS
I have a shape file from Mexico´s INEGI site that doesn´t have prj file. I am having trouble defining the projection in Arc. INEGI tells me it is projected as Lambert Conformal Conical with a ITRF92 GCS. From what I understand, this GCS should be the same as WGS84 (I have used this with other INEGI files and it matched). This combination of LCC & WGS84 doesn´t exist in ESRI´s system, so I tried to create a custom projection coordinate system with the following information given by INEGI:
longitude of origin: -102.0, latitude of origin: 12.0, standard parallel 1: 17.5,standard parallel 2: 29.5, false easting: 2500000.0 m, false northing: 0.0 m
But this doesn´t work - Arc puts the file in Africa, not Mexico (though it seems to be the right scale).
I´m wondering if there is something going wrong with the GCS, for which INEGI gives this information:
Datum: ITRF92
Sphereoid: GRS80
Semimajor axis: 6378206.4
Inverse Flattening 294.9786982
These numbers are not the same as ESRI´s WGS84 or ITRF92, and I can´t figure out how to change them in the "Define Projection" tool.
