I have elevation data stored at 5 meter resolution in a raster file. I would like to go in and add this data into a database (lat, lon, elevation.)
I have another rasterfile with other data, also at 5 meter resolution, but it does not line up perfectly with the elevation data. So if I try to add this data by lat/lon lookup, a point with that precise lat/lon may not be found. (I am keeping 6 decimal places of accuracy on lat/lon.)
In other words, I would end up with something like:
(lat, lon, elevation, class)
(40.000001, -87.000001, 250, NULL)(40.000002, -87.000002, NULL, 1)
Some possible solutions I can think of:
- Combine the data prior to adding it to a database. This isn't ideal. I've looked online and the only way I see to combine two raster files into one band is with ArcGIS, which I don't have. This would hopefully automatically sync the elevation/class data to the same georeferenced point. In this case, I would not allow any NULL values.
- Somehow map every lat/lon so that the above two points map to the same lat/lon pair value and store that lat/lon in the database.
- I see some databases are designed to deal with GIS...so maybe there is something I can look into?
