I have a script that goes over all the feature classes within a geodatabase (in ArcGIS 9.3.1) and copies them. The problem (as far as I can understand) is that when the script goes to a empty feature class, the script fails and gives the following error:
: Failed to execute. Parameters are not valid.ERROR 000732: Input Features: Dataset Parcels_border does not exist or is not supportedFailed to execute (CopyFeatures).
How can I get the code to skip over empty feature classes? I tried to do a GetCount() with a if clause - if empty then skip and so on - but even the GetCount() doesn't deal well with empty feature classes either(it puts out the same error).
Does anyone know how I can overcome this error?
EDIT: Hearing to Matt's advice, here's my script:
# Import system modulesimport sys, string, os, arcgisscripting# Create the Geoprocessor objectgp = arcgisscripting.create(9.3)# Load required toolboxes...gp.AddToolbox("E:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx")# Local variables...cop_dictionary = {"xxx":"rozetta","yyy":"height_line","zzz":"walls_fences"} part_path = "I:\\Users\\john\\" #setting part_path for iter in cop_dictionary: path = part_path + cop_dictionary[iter] + ".shp" if (gp.GetCount(iter)!=0): gp.CopyFeatures_management(iter, path, "", "0", "0", "0") gp .AddMessage(iter + "has been exported") else: gp .AddMessage(iter + "Is Empty")XXX,YYY,ZZZ are feature class (FC) names in a non-english font taken from a geodatabase which is opened in the ArcMap TOC. The non-english font is not a problem, as it runs through the first FC (XXX), and exports a intact shapefile. The error above appears in "YYY" which is a existing and empty FC.
Thanks a million.
SECOND EDIT: tried the 2 following answers below, both good (and teaching), but none of them solved the problem. It seems the problem isn't empty FC, but FC with some thing wrong in them (I can't pinpoint what). I haven't solved the problem , but left the problematic FC out until I figure out the problem.
Thanks a million.
