DataReviewer Geometry check on String and Int
I just started using Data Reviewer and went to compare two feature classes. A polygon of Parcels and a feature class of Points of addresses. I want to compare the address to ensure the address number is the same where they are on top of each other. The problem is that the Address field in the Parcels Feature Class is a string whereas the Address Feature class is an integer. I need to be able to convert the Addresses field in the points feature class to String just for this check.
Let me know if you need anymore information.
