Database connection (SDE) failed after database was renamed
I created an enterprise geodatabase in SQL Server 2008 R2 with ArcCatalog (10.2). It was connected via an sde file in ArcCatalog then.
Then I had to rename the database from SQL Server Management Studio.
After I did renaming the sde file no longer worked. The message is:
"Failed to connect the specified server. Do you want to continue? Operation Failed" I am sure the connection properties are correct as I only rename the database, and the Database I selected to connect is the new name.
Any idea? Thanks!
