When using a GIS to analyse spatial data, there is sometimes a tendency to assume that all data, both locational and attribute, are completely accurate. This of course is never the case in reality. Whilst some steps can be taken to reduce the impact of certain types of error, they can never be completely eliminated. Generally speaking, the greater the degree of error in the data, the less reliable are the results of analyses based upon that data. This is sometimes referred to as GIGO (Garbage in Garbage Out). There is obviously a need to be aware of the limitations of the data and the implications this may have for subsequent analyses.
Data quality refers to how good the data are. An error is a departure from the correct data value. Data containing a lot of errors are obviously poor in quality.
Data quality parameters Key components of spatial data quality include positional accuracy (both horizontal and vertical), temporal accuracy (that the data is up to date), attribute accuracy (e.g. in labelling of features or of classifications), lineage (history of the data including sources), completeness (if the data set represents all related features of reality), and logical consistency (that the data is logically structured).
Data Completeness: Completeness refers to the degree to which data are missing - i.e. a complete set of data covers the study area and time period in its entirety. Sample data are by definition incomplete, so the main issue is the extent to which they provide a reliable indication of the complete set of data.
Data Consistency: Data consistency can be termed as the absence of conflicts in a particular database.
Data compatibility: The term compatibility indicates that it is reasonable to use two data sets together. Maps digitised from sources at different scales may be incompatible. For example, although GIS provides the technology for overlaying coverages digitised from maps at 1:10,000 and 1:250,000 scales, this would not be a very useful exercise due to differences in accuracy, precision and generalisation.
To ensure compatibility, data sets should be developed using the same methods of data capture, storage, manipulation and editing (collectively referred to as consistency). Inconsistencies may occur within a data set if the data were digitised by different people or from different sources (e.g. different map sheets, possibly surveyed at different times).
Data Applicability: The term applicability refers to the suitability of a particular data set for a particular purpose. For example, attribute data may become outdated and therefore unsuitable for modelling that particular attribute a few years later, especially if the attribute is likely to have changed in the interim.
Data Precision: Precision refers to the recorded level of detail. A distance recorded as 173.345 metres is more precise than if it is recorded as 173 metres. However, it is quite possible for data to be accurate (within a certain tolerance) without being precise. It is also possible to be precise without being accurate. Indeed, data recorded with a high degree of precision may give a misleading impression of accuracy.
Data Accuracy: Accuracy is the extent to which a measured data value approaches its true value. No dataset is 100 per cent accurate. Accuracy could be quantified using tolerance bands - i.e. the distance between two points might be given as 173 metres plus or minus 2 metres. These bands aregenerally expressed in probabilistic terms (i.e. 173 metres plus or minus 2 metres with 95 per cent confidence).
Currency: Is my data “up-to-date”? introduces a time dimension and refers to the extent to which the data have gone past their 'sell by' date. Administrative boundaries tend to exhibit a high degree of geographical inertia, but they are sometimes revised from time to time. Other features may change location on a more frequent basis: rivers may follow a different channel after flooding; roads may be straightened; the boundaries between different types of vegetation cover may change as a result of deforestation or natural ecological processes; and so forth. The attribute data associated with spatial features will also change with time.
These components play an important role in assessment of data quality for several reasons:
1. Even when source data, such as official topographic maps, have been subject to stringent quality control, errors are introduced when these data are input to GIS.
2. Unlike a conventional map, which is essentially a single product, a GIS database normally contains data from different sources of varying quality.
3. Unlike topographic or cadastral databases, natural resource databases contain data that are inherently uncertain and therefore not suited to conventional quality control procedures.
4. Most GIS analysis operations will themselves introduce errors.
Data Errors
It is possible to make a further distinction between errors in the source data and processing errors resulting from spatial analysis and modelling operations carried out by the system on the base data. The nature of positional errors that can arise during data collection and compilation, including those occurring during digital data capture, are generally well understood, and a variety of tried and tested techniques is available to describe and evaluate them.
