Yesterday I asked what would be the best method of creating an overlay in a web map that would allow for some interactivity.
Create interactive map with no server
Thanks to a variety of people who recommended I go down the D3 and Topojson route.
The example that looks like the perfect solution is http://bl.ocks.org/mbertrand/5218300
So I created a topojson from an ESRI Shapefile using the following command
topojson --id-property full_name -o southeast.json southeast.shpI have since tried every possible permutation and example to try and get the topojson loaded and I have hit a brick wall. I just do not understand what I am doing wrong.
I have used the following examples
http://www.schneidy.com/Tutorials/MapsTutorial.htmlhttp://stackoverflow.com/questions/14492284/center-a-map-in-d3-given-a-geojson-objectConversion from Shapefile to TopoJSON format results in incorrect map when rendered using d3jshttp://milkator.wordpress.com/2013/02/25/making-a-map-of-germany-with-topojson/
and Mike's original example
http://bost.ocks.org/mike/map/
Maybe it is because i am not using EPSG:4326, but this example says that you do not have to use a projection
http://bl.ocks.org/mbostock/5557726
The data can be found here - https://www.dropbox.com/s/dfxxi4xwrsdfa8t/southeast.json
And this is my code
var width = 500, height = 500;//null projection as my ESPG is not supportedvar path = d3.geo.path() .projection(null);var svg = d3.select("body").append("svg") .attr("width", width) .attr("height", height);svg.append("rect").attr('width', width).attr('height', height) .style('stroke', 'black').style('fill', 'none');//d3.json("southeast.json", function(error, south) { //console.log(south);//});d3.json("southeast.json", function(error, uk) { svg.append("path") .datum(topojson.feature(uk, uk.objects.southeast)) .attr("d", d3.geo.path().projection(null));});I first tested with sending the data to the console and that worked fine and told me that the object is "southeast".
If I try this I get an n is not defined error in Firebug.
I then tried
// d3.json("southeast.json", function(error, south) {// svg.append("path")// .datum(topojson.feature(south, south.objects.southeast))// .attr("d", d3.geo.path().projection(null))// .style("fill", "red")// .style("stroke-width", "1")// .style("stroke", "black");// });Which seems to work as there are no Firebug errors, but no data is visible
Then I tried
// d3.json("southeast.json", function(error, uk) {// svg.selectAll(".southeast")// .data(topojson.feature(uk, uk.objects.southeast).features)// .enter().append("path")// .attr("d", path)// });And the same thing happens
With no errors I am struggling to understand what I have done wrong
If I could just make this example work in EPSG:27700 with my topojson it would be amazinghttp://bl.ocks.org/mbertrand/5218300
Thanks
EDIT
One of the other answers was to use a simply getJSON function and add the data as geojson in OpenLayers. I have just tested it using the same topojson:
$.getJSON('southeast.json', function (data) { fusiegem = topojson.feature(data, data.objects.southeast); var geojson_format = new OpenLayers.Format.GeoJSON(); var vector_layer = new OpenLayers.Layer.Vector(); osMap.addLayer(vector_layer); vector_layer.addFeatures(geojson_format.read(fusiegem)); });And that successfully loaded, so it seems there is nothing wrong with my topojson file, it is the D3 bit that does not seem to work correctly
And this is my code
I then tried
Then I tried
Thanks
EDIT
