Creating empty group layer within existing group layer using arcpy.mapping?
Referencing this question, Add a new group layer with python ArcGIS 10, I'm trying to use python to add a empty group within a group layer. So far I'm able to add a empty group within the map document, however I'm getting an error when trying to add another empty group within the existing group layer. Here is the error message:
Runtime error Traceback (most recent call last): File "", line 1, in File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\utils.py", line 181, in fn_ return fn(*args, **kw) File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\mapping.py", line 88, in AddLayerToGroup assert isinstance(target_group_layer, Layer) and target_group_layer._arc_object.isGroupLayer AssertionError
Here is my code:
mxd = arcpy.mapping.MapDocument(r"C:\Temp\test.mxd") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] groupLayer = arcpy.mapping.Layer(r"C:\Temp\Group.lyr") arcpy.mapping.AddLayer(df, groupLayer, "BOTTOM") targetGroupLayer = arcpy.mapping.ListLayers(mxd, "Group", df) addLayer = arcpy.mapping.Layer(r"C:\Temp\Group2.lyr") arcpy.mapping.AddLayerToGroup(df, targetGroupLayer, addLayer, "BOTTOM") # error here mxd.save() del mxd,dfCan you add empty group layers within an existing group (using v10.1 SP1)? The ESRI documentation (see image below) states that you can add .lyr to groups (maybe not a .lyr group layer?).
Thanks
UPDATE
Here is the working code (thanks to Jason Scheirer):
mxd = arcpy.mapping.MapDocument(r"C:\Temp\test.mxd") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] groupLayer = arcpy.mapping.Layer(r"C:\Temp\Group.lyr") arcpy.mapping.AddLayer(df, groupLayer, "BOTTOM") targetGroupLayer = arcpy.mapping.ListLayers(mxd, "Group", df) addLayer = arcpy.mapping.Layer(r"C:\Temp\Group2.lyr") arcpy.mapping.AddLayerToGroup(df, targetGroupLayer, addLayer, "BOTTOM")[0] mxd.save() del mxd,df
