all. I'd like to find a way to add coded values to a Text domain using values from a table field, if such a thing is even possible. I'm using the Add Coded Value to Domain tool connected to two variables: Name and Description. While this hasn't worked yet, what I've tried was making the value of each variable the same as the two field names from my table with the name and description I'd like to have. My syntax for Name was %VendorName% and my syntax for Description was %VendorDescription%. All this does is create a string literal %VendorName% coded value. Is what I'm trying to do possible?
