Creating and re-using map template in ArcMap?
I am using ArcMap 10.1 and working on a project which requires 5 different analyses on the same data. I created five map documents (.mxd) and completed my analyses. Now, the problem is that I want to export my results in map format but I want them to be uniform in display i.e. having a same map template. Is there a way to save one of the maps as a template and then use it for creating other 4 maps?
I tried saving one document in 'Map Templates' folder in ArcGis folder but a message box appears which says that I don't have permission to save in that location and I must contact administrator for that, even though I am the only user and administrator of the computer. I don't want to manually add all map elements for 5 different maps, thats too tedious!
