Creating a value-counting table with search- and update cursor
first post here. I'm a python beginner.
I`m working with ArcGIS 10.2.2 and IDLE Python 2.7.5
I have a shapefile with around 20 fields, each attribute has a value between -3 and 3.
This would look like this:
I need to count the number of occurences of each value for every object. For this I created a new shapefile with fields where the values get counted:
The actual counting is my problem.My approach is to browse with search and update cursor through the files. My script does work, however there are two problems:
1.It is really slow (for a shapefile with 300 rows the programm ran over 9 minutes). I tried using the arcpy.da.searchcursor but I couldn´t bring it to work.2. The way I builded up the script seems a little odd. I tried a lot to make it easier, but I cannot really figure out which way to go. I believe there is an easier way to do it.
try:#getting the fieldnames and creating a searchcursor fieldnames = arcpy.ListFields("Eignung") srows=arcpy.SearchCursor("Eignung",fieldnames[2:18]) print "operating"#creating a while loop to work row by row srow = srows.next() while srow:# for every field in the row I get the Value for fieldname in fieldnames[0:18]: TheFieldName=fieldname.name TheValue=srow.getValue(TheFieldName)#if the Value is 0 I add "1" to the "zerofield" in the counting table if TheValue == 0: obj_id = srow.getValue("OBJECTID") urowquery = '"OBJECTID" ='+ str(obj_id) urows = arcpy.UpdateCursor("Eignung_1",urowquery) for urow in urows: urow.setValue("Null_",urow.getValue("Null_")+1) urows.updateRow(urow) obj_id +=1 del urow, urows print "check0"# and do the same thing for 1 and 2 and 3 and so on elif TheValue == 1: obj_id = srow.getValue("OBJECTID") urowquery = '"OBJECTID" ='+ str(obj_id) urows = arcpy.UpdateCursor("Eignung_1",urowquery) for urow in urows: urow.setValue("Eins",urow.getValue("Eins")+1) urows.updateRow(urow) obj_id +=1 del urow, urows print "check1" elif TheValue == 2: obj_id = srow.getValue("OBJECTID") urowquery = '"OBJECTID" ='+ str(obj_id) urows = arcpy.UpdateCursor("Eignung_1",urowquery) for urow in urows: urow.setValue("Zwei",urow.getValue("Zwei")+1) urows.updateRow(urow) obj_id +=1 del urow, urows print "check2" elif TheValue == 3: obj_id = srow.getValue("OBJECTID") urowquery = '"OBJECTID" ='+ str(obj_id) urows = arcpy.UpdateCursor("Eignung_1",urowquery) for urow in urows: urow.setValue("Drei",urow.getValue("Drei")+1) urows.updateRow(urow) obj_id +=1 del urow, urows print "check3" elif TheValue == -1: obj_id = srow.getValue("OBJECTID") urowquery = '"OBJECTID" ='+ str(obj_id) urows = arcpy.UpdateCursor("Eignung_1",urowquery) for urow in urows: urow.setValue("Eins_minus",urow.getValue("Eins_minus")+1) urows.updateRow(urow) obj_id +=1 del urow, urows print "check-1" elif TheValue == -2: obj_id = srow.getValue("OBJECTID") urowquery = '"OBJECTID" ='+ str(obj_id) urows = arcpy.UpdateCursor("Eignung_1",urowquery) for urow in urows: urow.setValue("Zwei_minus",urow.getValue("Zwei_minus")+1) urows.updateRow(urow) obj_id +=1 del urow, urows print "check-2" elif TheValue == -3: obj_id = srow.getValue("OBJECTID") urowquery = '"OBJECTID" ='+ str(obj_id) urows = arcpy.UpdateCursor("Eignung_1",urowquery) for urow in urows: urow.setValue("Drei_minus",urow.getValue("Drei_minus")+1) urows.updateRow(urow) obj_id +=1 del urow, urows print "check-3" srow = srows.next() print doneAs I said, it does work, but it doesn´t work good. Recommendations and help appreciated. Thanks and happy coding
