create route network by connecting points together
I have a .csv dataset containing 2 X,Y coordinates. I want to create 3 layers, a point map of the first X,Y coordinates (start position), a point map of the second X,Y coordinates (end location) and a line layer connecting these two points. The connection must be on a road network and has to calculate the fastest route.
I have a road network containing max speed and created a network dataset with this in ArcMap. I want to use the network analyst tool and use closest facility option, but this would not be correct. Some points have not the closest end location, but somewhere else on the map. How can I make such a line dataset based on the .csv file I have and the network dataset. Do I do this with the network analyst?
