Create Envelope based on center point
I see in the Java SDK : https://developers.arcgis.com/java/api-reference/com/esri/core/geometry/Envelope.html they have :
Envelope(Point center, double width, double height)Creates an envelope by defining its center, width, and height.
However, in the .NET Desktop Runtime SDK no such constructor exists that I can find:
https://developers.arcgis.com/net/d...ml/T_Esri_ArcGISRuntime_Geometry_Envelope.htm
https://developers.arcgis.com/net/d...ri_ArcGISRuntime_Geometry_EnvelopeBuilder.htm
Is this functionality lost in .NET?
If so I am curious how I can take in a longitude and latitude in 4326 (WGS84) spatial and then create an envelope around the point with set radius in meters. I believe I have to first create the MapPoint then convert it from geographic WGS84 to a meter projected coordinate and then find the four corners and then plug those into the EnvelopeBuilder. I am just wondering if this is the correct way or if there is an easier way such as Java SDK.
Which projection should I convert WGS84 into for this to work as I am wanting it to?
