Is it possible to create an OLE DB connection (*.odc) to a database in ArcGIS 10 , but using Python instead of the ArcCatalog GUI wizard? I don't need to necessarily create a file on disk, just make the connection to the database. I am trying to automate a procedure that many users may use, and do not want to rely on every user remembering to create the OLE DB connection manually through ArcCatalog.
The Python code provided by @blord-castillo in a similar question shows How to create an SDE Connection using Python, so I am looking for something similar that creates an OLE DB connection. I cannot seem to find any reference to any Python code for this task.
Eventually, the python code sample using Make Query Table is basically what I want to do, but it assumes you already have your *.odc connection built.
Anyone have suggestions or pointers for places to look for sample code? I am working against a SQL Server database, in case that matters.
