I am currently working to integrate an RTK GPS system into a sensor fusion framework. The framework is based on an Extended Kalman Filter, which is why I need an accurate estimate of the measurement covariance matrix for both RTK fixed and RTK float mode.
Are there any common methods to do this?
All I could find so far is to use noise-adaptive Kalman filtering, as they do in this paper (section III A). However, since most RTK GPS receivers output the covariance matrix directly, I assume there must be other methods to do this independent of the Kalman Filter in the sensor fusion framework?
Thanks in advance for all help!
